I'm sold on DG AW
Has anyone used AW on the interior of the car? This past weekend I used it in my wifes car. On the dash, A/C & stereo controls. It gives a nice little shine with a good scent. It obviously wont clean but I like it for a good wipe down.
TigerMike said:
As long as there are no oils in either PS or OS, the AW should not have a problem working with either product. The polymers in AW are pretty friendly and will work well with most other polymer products. If there are any oils present on the paint surface though, the AW may not form a bond as strongly as it normally would.
Mike--do you use the AW as a detail spray say after each wash or only on occasion to boost the 105?
I personally use AW after every wash now. It isn't necessarily needed after every wash, because it should easily last between multiple washes. But, I find it's so easy to refresh the AW layer(s), that I apply after each wash for another boost in protection, gloss, wetness, and shine. You certainly don't have to use it that often though....once or twice a month would be fine also.
I use the AW a lot and use it like a QD , so easy and an awesome LSP IMO. I talked with Bill @ DG and layering was not an issue . The whole DG system is designed to be layered.
