Accumulator
Well-known member
jtaylor said:Thank you for the advise, although I may have the curse of Autopia. I don't think I will do this professionally, its more of therapy/hobby in a way. In reality, I'm not satisfied with the way it looks, although my friends and family say it looks perfect. I just ordered the CG Foam gun, another grit gaurd, and new MF towels from CG. To hep reduce the chances of me instilling more scratches because the paint is rock hard to remove swirls...
Note that there's a real knack to using a foamgun effectively. I *DO NOT* find "presoaking" with foam to be very effective, for instance. I shoot foamgun output at the point of wash medium-to-paint contact to "flush away the dirt".
With the foamgun, I have no use for grit guards as my rinse water (let alone my wash water) stays very clean. My approach is "dislodge and flush" so the dirt never makes it to the rinse bucket.
I have been able to achieve good correction with Meg's d300/mf. I do not have the talent to use the bottle of 105 without it instantly flashing on the paint.
OK, just use whatever works best for you. I trust you're only using such aggressive stuff every year or two. But you'll probably need to go over that remaining marring a bit more to really get it out.
I'd probably try to sort out the wash/dry regimen first. Not a whole lot of point in getting things perfect until you can keep 'em that way.
Winter regimen - I live in the CA Bay Area, and never gave much thought to winter prep, anything I should do? I have only seen undercarriage dressings but nothing to actually protect. I have HD Poxy on the care now, should I strip it and apply the Nitro?
Ah, that's different :think: What are your winters like there?
Here in Ohio (nasty, nasty winters...with lots of salt) I don't really do much of anything different. But then I'm a nut about my undercarriages/etc. anyhow. During the winter I just do the same stuff more often.
