mnbv said:.. for "extracting" is the wet/dry vaccum to suck up the moisture what you are talking about? When I rinse, should I fill up a spray bottle with hot water and spray a bunch of times?
Auto Care USA said:If it's a browning problem call Hesco Inc. and ask them for their browning stain remover. Their phone # is 1-800-822-7467
It's sorta the same thing, but most (good) extractors also spray the (*hot*) cleaning solution *deep* into the carpet with high pressure, and they often have more suction than a wet/dry. Still, the wet/dry is much better than nothing/blotting.
Upscale Detail said:You mentioned using Woolite on this carpet stain. Have you made sure that it is wool? Most of the newer carpet fibers are synthetic.
"a mild fabric wash created to safely and effectively care for natural and synthetic fine washables. WOOLITE® will not damage washable fabric fibers. It helps preserve the color of your clothes and keeps them looking vibrant. It also helps to keep your clothes fitting the way they were designed to fit, without causing shrinking or stretching. WOOLITE® Fabric Wash does notcontain bleach, oils, phosphates, or enzymes. Results conclusively show that if a garment is safe in water, it is safe in WOOLITE® Fabric Wash."
gnahc79 said:Woolite is not only for wool, confusing I know. It might have been back in the day, but Woolite is:
Upscale Detail said:You mentioned using Woolite on this carpet stain. Have you made sure that it is wool? Most of the newer carpet fibers are synthetic. Try mixing a spray bottle of 16 oz water with 1/8 - 1/4 scoop of OxyClean granules and soak the entire area. Agitate gently with a brush. Blot up stained areas first, then reapply.
I have a steamer, which helps, but most of the time OxyClean will get out just about anything, including the abused carpet from this 1983 Datsun 280ZX. Wish I had pictures "after", but entire car looked like this and I was able to clean all of it with OxyClean.
