SVR
Dream Machines
To be honest, I don't like the methods on that video.
Water is being sprayed directly at the paint, not sliding along it the paint
mitt being used with not enough solution and covering too larger area between mitt cleaning in second bucket.
Best thing to do. Don't worry about the water pre wash rinse.
Go straight to a foam gun, use two to seven mitts (one per panel), blot and gentle glide motions with the mitts. Dunk each mitt in bucket, apply a big drop of shampoo to it and before starting each panel, wring all the solution out.
Then re dunk and first blot and finish with a gentle glide
Rinse with flooding method. Spray any QD or spray sealant (can't be AJT), wait two mins then rinse again.
Dry glass and door jambs. Then go over the paint.
It should be spot free and bone dry in some sections of each panel.
Only blot with a waffle. never glide or drag.
For all newbies reading this. Use the search function and PM any of the true pro's on here if you need more info or cannot find what your looking for
