mikebai1990
We recently found that the Acura had been leaking coolant quite badly and found that a part of the coolant hose had slipped out of it's original secured position. Once out of the position, the hose was situated next to the belt, so the belt wore a hole in the coolant hose.
What products do you think I can use to seal up this damage? I would say the hole is approximately 1 cm x 1 cm, possibly even smaller. I believe that the coolant system undergoes a lot of pressure, so I guess silicone sealant might not do the job. What products would you guys recommend?
