togwt
The Old Grey Whistle Test
Quote: cause all that work of waiting 24 hours between each coat or something. i don't think is very practical.
~One man’s opinion / observations ~
Zanio is a synthetic polymer wax, a compromise between a polymer sealant and a natural wax. The polymers do not require a lengthy cross-link (cure) time as ZFX is formulated to accelerate the time requirements. Z-2 produces the most gloss of the two synthetic waxes (although they’re labelled as polishes) it is more optically clear then Z-5 and will highlight any surface imperfections, whereas Z-5 will ‘hide’ very minor surface imperfections with fillers.
Using Zanio’s ZFX accelerator there is no need to wait between “layers’
By applying more products on top of one that has already cross-linked you can increase it’s density (up to a point). The thin film of product that’s applied isn’t really another layer.
Each subsequent applications adherence process is that the solvents work their way into the microscopic gaps and valleys of the previous ‘layer’ thereby creating an anchor, and by surface tension, when the paint film surface is level then this density can no longer be increased (i.e. there is nothing to anchor to)
A level paint film surface improves the paint film surface’s desired optical properties (i.e. surface reflectance, clarity, gloss, and depth of shine)
~Hope this helps~
Experience unshared; is knowledge wasted…/ Jon
justadumbarchitect *so I question everything*
~Hope this helps~
