How important is it to use a pH balanced wash?
It seems all of the washes out there have different pH levels. How important is it to select a car wash that has a neutral pH, and what are the effects of using a wash that has a higher pH level? Do the higher pH levels strip away wax and protection quicker? I was curious on a few products, so I contacted Meguiars on some of their products and here's the pH levels on their washes.
NXT Generation = 8.5
Gold Class = 8
Now I believe that Zaino Z7 is supposed to be pH balanced at 7. Is there any other washes out there that contains a netural pH level.
I'm just curious on how pH levels affect finishes and other trim on vehicles, or if it doesn't really make a difference.
That's way too high, it should be between 6.9 and 7.8 to be PH neutral
Having a high PH means its quite alkalinic and can take alot of slickness out of the paint, dry out exterior vinyl and rubber trims and hurt sealers and waxes to some degree (possibly), though how much depends on the brand
Shampoo's at 6.8 and below will definately be a problem to sealers and waxes and I'd imagine some loss of shine over a long period of use
I've got PH testing strips to test all of my shampoo's in the bottle and when mixed in with water (in the buckets)
Won't the final PH depend on how much and how acidic/alkaline the water you're using is? I'm just refering to my fish tank days where PH had to be perfect and you sometimes added water to level out your ratio.
Thanks for clarifying that. From your testing, what kind of shampoos and washes would you recommend that seem to be in the neutral range?
You could buy some PH paper or a tester if you need to.
As most city water varies and is usually 7.5- 8.5 PH (one reason to keep the pipes clean) as long as the shampoo is around neutral is will be OK.
APC cleaners are usually much more extreme. 2.0 or 11 PH. Though some newer ones are closer to neutral.
RedlineIRL said:
I'm just going by what Sal told me, which was a pH of 7.0. Is it not neutral?
:nixweiss I'd never heard that before, but I just mixed a little up in a cup and it did seem to be about 7, tasted pretty good, too.
Duragloss, Driven to Perfection, Einszett Perls and Jeffs Werkstatt all were in the neutral range
Can't say anything about other brands as I have not tried them
AutoInt/ValueGuard's "C" shampoo is ph 7.0.
But yeah, that's about the least important thing IMO. None of the major-label shampoos are gonna be so far off neutral as to cause problems and there are a lot of considerations that're more important.
I ran some pH tests yesterday.
DI water from my lab came out to 5.94.
Not good.
I will test Tap, distelled, and culligan water again today to find out their pH.
I will also bring in some ONR tomorrow and meg's gold.
test them with the various waters.
I am using a Accumet basic AB15 pH meter.
If anyone would like me to test anything let me know.
lol, i can be an "independent lab tester"
sulla said:
Wow..You said you're going to test ONR ?
Yup.
Im going to bring it in tomorrow.
Im going to try and break the ratio 1oz to 2 gal down tomorrow to a more testable size.
and i might try to test it as is as well.
I might also test for Conductivity, Resitivity, and Total Dissolved Solids(total amount of dissolved ions)
yup, so i forgot all the stuff.
sorry. I have tomorrow still.
Ill leave my self a note.
Once i have enough Data i will probably post a new thread.
I will try to do simple green and Zep's Citrus degreaser.
Optimum No-Rinse has a pH of 5.12
Megs Gold Class has a pH of 8.5.
Odd findings.
if ya mixed them they would be more nuetral lol.
wannafbody said:
Isn't 5.12 fairly acidic?
it is on the acid side, yes.
I did another test of the DI water and that was a 4.93pH
( i think something is up with our DI)(I willl try to get a replacement but it is still showing its good.)
Using the aforementioned DI water and ONR i also did a test.
Using Approx 1892ml of DI water and 7.5ml of ONR(which is the same as 2gal to 1oz), stirred with a magnetic stirrer for a minute or two
came out to 4.68pH
so now im not sure if i want to wash my car that was recently waxed with this set up.
I will be trying the culligan water as id is more basic than distilled next.
i just hate wasting my ONR lol
