chromecarz00 said:
Hi all,
used the mothers claybar a lot before I found this site. In fact I used it so much taht it actually began to disintegrate into yellow liquid when I used it. Of course I know that this is way too late to dispose of it; however, I just bought the Meguiars claybar, and Im not sure how much to use that. How do I know when the claybar is ready to be thrown?
Pictures Im sure would help illustrate.
THanks
Can't help via pics, let's see if I can explain anything worthwhile..
Yeah, once the clay goes soupy (often a matter of something compromising it- wrong lube, some solvent) or crumbly, or it quits working effectively, then it's time for new clay.
Another reason to retire it is contamination; when the clay is so contaminated that you can't refold/knead it to expose a clean area. You don't want to rub contaminated clay across the paint lest the contaminants cause marring (but this clay might still be OK for wheels/etc.). This is like when you accidentally drop your clay...90% of the time it's not a good idea to keep using the dropped clay because you just never know what it might've picked up.
Yeah, you can fold/knead the clay so the contamination is hopefully moved away from the part of the clay that's touching your paint, but I dunno...the [stuff] is still in there and a lot of the stuff I clay off is stuff I do *not* want rubbed against my paint.
*IMO* you oughta replace the clay pretty frequently, before the risk of marring from embedded contamination becomes an issue.
I like to tear my clay into sorta-small pieces and then replace these sorta frequently, pretty much as soon as they're contaminated. This is good if/when you drop it too, as it's just a little piece getting trashed.
