V_Eight
I wish I detailed good
Looks incredibly wet, and I want it!
joyriide1113 said:A lot of "shiney" dressings will do that on that particular tire. Look at how smooth the sideall is with little ridges and writings.
Thats actually why my next tires will be the "Michellin Pilot Sport PS2's".
Better performance than my Potenza S-03's and will look better when dressed with any waterbased dressing.
Poorboy said:Use a high solvent based dressing that will not dry and kick up all over the car when you drivebtw...look at the ground around the tires and you'll see a yellow stain..guess where it came from :whistling: don't step there you'll go sliding:horse:
I bet a couple of coats of the high gloss version of Megs Endurance Tire Gel will get you pretty close to that look. Of course as everyone else has said a smooth sidewall contributes to the shine and unwiped dressings will likely sling all over the place.V_Eight said:I assume that stain is from a spray on dressing now that you mention it.
I use endurance extensively, I wonder if, after multiple coats, I could see similar results on a similar tire.
harry444 said:You can lso get the same results with a (belive it or not ) can of PAM cooking spray except don't go near a puddle of water >>My stang looks as good as that one!
vwgtivw said:Good old Black Magic tire dressing, but if you drive you car it will be all over it.
Djmigs said:one word "Vaseline" apply at your own risk
Jngrbrdman said:Leave it to a dealership to keep that much Vaseline in stock. :lol: Only they would have the need for industrial amounts, if you know what I mean. :nutkick
