Bought a CR Spotless unit 2 weeks ago - I cleaned 2 cars with it (using it only on the final rinse so as to not wear out the resin too quickly), both dried spotless. Fast forward 2 weeks to today - cleaned my Z06 with it on final rinse, turned around, and it was spotting like crazy.
I looked at the TDS meter and it was reading 50! Figuring maybe I let the water sit too long in it, I opened up the blue cans and drained all the water out. Then I hooked it back up and ran the water through it. For the first 20seconds or so the meter hovered between 0 and 10ppm, then shot up to 100ppm, back down to 40ppm, and hovered between 50 and 55ppm.
Is my water that filled with **** that it only takes 2rinses (~4gallons of water total) to kill the resin cartridge? That can't be right! Did I get bad/old resin cartridges?
I figure I'm going to re-fill them with my backup resin and see what happens. I'll also add in an inline filter to see if that helps at all.....I remember reading about some inline filter you can buy at home depot (???charcol filter???) but I can't remember what it was now. Any advice would be appreciated.....
