I have a problem on my car with swirling. Like reeeaaal bad. I have been good on keeping the car clean and glossy, but I haven't really done any restorative type work to remove scratches, swirls, etc. I wash, clay and wax almost every weekend ( I usually clay once every two or three weekends), and the car looks good from a distance, but up close the paint is horribly swirled.
So, with this in mind, I decided to attempt to try to remedy this yesterday. I washed (Meg's Gold Class and Wool Wash Mitt), clayed (mothers gold clay with mothers QD), and washed again to remove clay residue. Now first I must mention that I have no PC, so everything right now is by hand. I picked up the Meg's deep crystal 3 step polishing system. I applied step one and two by hand with foam pads. The bottle said to simply apply, which seemed extremely vague to me. At first I just spread it on like wax, and then wiped off with a MF towel. This seemed to do nothing at best, so I started applying in a scrubbing manner, going back and forth in one direction. I didn't put alot of pressure on it, but I went back and forth around 30 times for each 2' x 2' area.
As it ended up, the process didn't do much. If anything the swirling was diminished a tiny bit, but it would only be noticeable if you really stared at it. I don't know if it was because I didn't "apply" it for long enough, or if the hand application didn't really do as good of a job as a PC/Rotary. Either way, the end result didn't help.
So now I ask the detailing masters that reside in this place known as autopia. How should I go about this? I've thought about purchasing a PC and related materials, but Im still 50/50 on it. Is it truely the answer to my problems, or can I get by with doing things by hand? Also, what should I look at in terms of polishes? Im thinking either SFX-1 or SSR2.5/SSR3 and then moving down the spectrum to get it back to a smooth deep shine.
Lastly, what is the best method for applying things by hand? The instructions for most products are incredibly general, so im looking for some more in depth instruction.
Thanks folks :buffing:
