I don't post much but I lurk a lot. I really respects the work you pro's do and I'd like your help to prove someone wrong.
On another one of my forums someone asked about how to repair small scratches in his clearcoat of his economy car. This was the first answer that was given (before I got in there of course)
And I called him out stating that's not how buffing works and that if it worked that way all you'd need to correct a scratch would be a heat gun. I also attempted to educate him on the differences between a rotary and a dual action polisher, but he won't catch on. (I won't quote it because it's too wordy)
And his reply:
Anyone care to help me out? :heh:
buffing should take that out if it is just in the clear coat. I am not talking about waxing, you need to use a buffer to heat up the clear so it will melt together and give you the glass finish it should have. I dont recommend that you do this if you have never buffed a car before. You would most likely cause more damage, but buffing is most likely how you would fix the problem.
And his reply:
Ok dude, you got buffing and brightening mixed up here. I dont know what stuff you work with, but what i said is true about buffing. And a g heat gun cant do that **** (called me a name). Not to mention, i have seen several people who have never buffed before burn right through the paint because they didnt move fast enough.
