Help me pick a Wheel Sealant
An advantage of Hydr02 is that, in a pinch, I recon you could do the barrels without taking the wheels off. Just rotate them if need be.
I use Hydr02 a majority of the time on wheels, unless people want to pay to upgrade and have a longer lasting coating applied in which I will apply DLUX.
Update: I decided on 845 in the barrels, then Hydr02 all over.
It's working great! :bigups
Much better than Armor All Wheel Sealant (or whatever it's called) and better than 915. I think the 915 melts off, and the Armor All product works to a point, then suddenly looks instantly worse.
How do these sealants/coatings effect sticky wheel weights?
Good question. My hope is that Hydr02 doesn't seep under the weights and loosen them. :( need to check. As far as adding new weights, I'll just IPA the barrels real good before taking it in.
