HRP said:Please register your location. Someone on this board will be nearby and probably can get you a sample of his favourite (and help you apply it). All of the choices above are great, but check the reviews on this site for sealants. You'll find that Zaino sealants are considered among if not the most durable. My preferences are to use Z-AIO followed by Z-2 or Z-5 PRO depending upon the color of the car. Z-5 gives a better result on darker cars and helps cover any blemishes. I put about 3 layers of Z-5 alternating with Z-2, Z-CS, and Z-8 on my dark cars. Since they are garaged when not being driven, the application lasts at least a year. But a good cleaning and a couple of layers of Z-5 PRO will give you great durability and look good.
DO NOT USE A SEALANT OVER WAX!!! You may use a wax over a sealant, however.
RTexasF said:Another vote for Duragloss #105. I have the Wolfgang and the look is incredible.....the durability is not.
dogma said:For metallic Zaino Z5,Z8 & ZCS. OS is also real good. I have been experimenting with a product from Deep Finish called SWAX, on metallic nothing looks better its deep,wet and the pop is awesome. If you don't care about durability CG Wet Mirror Finish is incredible . I have found that AJ & AJT mute the metallic as does more than one coat of AW. 105 is not bad but doesn't have the pop like some of the others.
MDRX8 said:Dogma, I have some SWAX sitting on the shelf that I have never tried. Need to give it a shot and see what happens.
dogma said:Not sure on the durability right now, but on metallic the looks are incredible.
I prefer to use my PC to apply. Also the more coats you put on the better it looks ( I have done up to 4 ). You have to try their QD DeepDetail.
Let me know how you like the Swax.
