help me choose one...
Envious Eric
extractors....for a mobile operation out of the bed of my truck!
the mini mean here
Hot Water Extractors Vacuums & Reclaims Hot Water Spotter Carpet Mean Portable Reclaims Extractors Vacuums Mini
the mytee lite II here
Hot Water Extractors Vacuums & Reclaims Mytee Heated Extractor Smaller Hp100 Version Light Extractors Water Vacuums Reclaims
mini mean info:
Standard Features:
# 1600 Watt Heating Element
# 102" Vacuum lift
# 60 psi pump
# 2 Gallon Water Tank
# 25 Ft 12 guage electrial cord
# 12 Ft Vacuum & Solution hose
# 4 Inch Clear Plexiglass Detail Tool
# 22 lbs Dry weight
# 1 yr Factory warranty on Pump, Motor, & Vacuum
# 5 yr warranty on Mold & Housing
mytee lite II info:
# Vacuum motor: 2 Stage
# Heater: 900 watt inline
# Pump: 100 PSI
# Water Lift: 85"
# Power cord: 25ft under 15 Amps
# Solution tank: Lift Off 3 Gallon
# Accessories: 15ft Vacuum/Solution hose 4" Stainless Steel Tool
# Handle w/Accessorie basket
# Dimensions: 16" x 21" x 36"
# Weight: 40 lbs
which one and why.....
the way i see it, the mini is 100 less for more lift (suction to remove more in one pass)
but the mytee is more PSI (to inject water harder?)
Mini Mean! Hands down, I own two and love them. It all depends on how big the vehicle is. If your talking about a filthy Excursion, with fabric seats, than you will need to refill and wait for warm up. I can usually do a moderately dirty van with cloth seats, no problem. Another thing to think about is size. Mini Mean is smaller and easier to move around. You can also look into Aztec, same as the Mini Mean. If so P.M. me and I will give you contact name and number.
Dave
Off topic, but I can't help but laugh at the ad for the mini mean - Comes with a "Free Professional Detailing Manuel".
Nothing beats getting a Mexican to do your work for free ROFL. Hot deal!
yeah its a mobile unit, hence the smaller size necessary....I dont mind refilling it, I can get the plastics cleaned while i wait the 15 minutes....
so which one grouse - from the two
How many cars do you do in a day?
If it is more than one a inline heating element is what you want. As it will heat the water as you use it.
a normal heating element will require time to heat up.
Of the two i prefer the myteelite.
However look at these two. They are a bit higher quality overall compared to the mytee lite.
TUFFY Price - $795.00*
Specifications:
Body Rotational Molded High-Density Polyethylene
Solution Tank 3 Gallon Capacity
Pump 55 PSI
Vacuum Motor 2 Stage Lamb Motor
Heater 1000 Watt In-Line
Vacuum/Extractor Hose 15’ 0�
Detail Tool 3� Stainless Steel
Power Cord 25’ 0�
Switches Waterproof
Amps 20
PYTHON Price - $1199*
Specifications:
Solution Tank 6 Gallon Capacity
Pump 100 PSI
Vacuum Motor 3 Stage Lamb Motor
Heater Dual 600 Watt In-Line
Power Cord 25’ 0�
Switches Waterproof
Amps 20
Soil Extractors
Soil Extractors
That Python looks a heck of a lot like my Mytee HP60, and I know that Mytee does private labeling...
the only reason I question it is the water lift....like 105 vs 85....is the mini going to suck more out faster, but take longer to heat up between fillings?
water lift is only part of the way you can tell how much the vac can suck. CFM, presure in HG, and Water lift all play a factor.
is 85-105 noticeable. yes. Difference in drying time? Well no. This can be negated by properly dry stroking the fiber face a bit slower. Is there a time difference between the two? not really.
Also 2 gallons should be enough for a minivan with leather. but maybe not enough for a mini with cloth. (depending how dirty it is)
If it was me i would buy this and put it in a trailer or van.
3000 psi, 100 gall fresh water, 80 recovery, 240 degrees at the jet at 300ft of hose in under two min. 405 cfm at 13" of HG.
it gives me school girl giggles.
Everest
Prochem's Next Generation Truck mount.
Before starting on the Everest, Prochem went out and listened to you, the end user and asked what you needed in a truck mount. Taking these ideas and making them a reality was the end goal. After you see the Everest, you’ll realize we have met and exceeded our goal.
Innovative Design Features:
Simplified design for no-hassle operation and maintenance.
Improved heat and vacuum for the ultimate in performance
Patented heat exchange system provides plenty of heat while
eliminating the need to bypass water to the waste tank
Tri-Lobe blower designed in partnership with Prochem and Sutorbilt for the carpet cleaning industry
provides smooth, quiet operation.
Perfect for large commercial jobs or de-flooding and water restoration work.
Last Step Chemical Injection for long life of water pump and heat exchange system.
High pressure circuit (up to 3,000 psi)
Electronic fuel injection automatically adjusts for altitud and heat exchange system.
Many other features you asked for and Prochem has delivered!
1. Chemical Simulator Valve – Simulates chemical flow without having to trigger wand to easily switch
between chemicals.
2. High Pressure Circuit – Creates up to 3,000 PSI for pressure washing (available on Everest HP only).
3. Hot Water Tap – fill up your Chemical jug with hot water to improve chemical performance.
4. Low Pressure Circuit – Creates up to 1200 PSI for carpet and hard surface cleaning.
5. Dual Wand Operation – True dual wand operation for large commercial jobs.
6. Shutdown Identifiers – Diagnose cause of shutdown and limit downtime.
7. Console Light – Allows easy-to-read control panel to be illuminated at night.
8. Electronic Fuel Injection – Eliminates the need for a governor, improves RPM stability and automatically
adjusts for altitude changes.
Specifications
Model: PPHP 100, PPHP, PP100, PP
49HP Nissan Engine with Electronic Fuel Injection: 2200 RPMs
Sutorbilt Tri-Lobe T408 Vacuum Pump: 405 CFM at 13� Hg
Cat 5CP water pump: 3000 PSI Max (Everest HP)
Water Flow Rate: 4.5 GPM
Waste Tank: 80 Gallons or 100 Gallons
Standard Equipment with Everest HP & Everest EFI
Pressure Hose: 150 ft. of 1/4" O.D. Pressure Hose
Vacuum Hose: 150 ft. of 2" Vacuum Hose
Water Hose: 50ft of Inlet Water Hose
Wand: Carpet Wand (quad jet)
Kit: Complete Installation Kit
Manuals: Operation and Service Manuals
Dimensions
Length: 47"
Width: 30.5"
Height: 39"
Available Models
PPHP 100: Everest HP w/100 gallon waste tank
PPHP: Everest HP w/80 gallon waste tank
PP100: Everest w/100 gallon waste tank
PP: Everest w/80 gallon waste tank
Can anyone name a unit that is pretty slim (fits into a sedan), can do 3 - 4 cars a week (3 sedans, 1 large vehicle), and is good quality.
TOL had a nice Ninja cold water extractor spotter that I liked for the size.
The Aztec is not a huge machine. Fits in a trunk nicely.
I have a Durrmaid and love it for what it is. You can't expect a machine of that size, or price to be just as good as a 13gal/13gal double circuit unit. But this thing packs one helluva punch for only $600. Night and day difference between this unit and dry extracting with a vacuum. The water that comes out is borderline too hot to touch. Buy from Bob, he's the man.
Hey Grouse,
Sorry to interrupt, I know I am hijacking,but do you have an opinion the the Cross-American machine (mitey-one)? I went back and forth in my head between the aztek/durrmaid/mytee for a long time and some carpet guys I was talking to reccommended this machine to me and it is what I went with. I also picked up the drop in 1000 watt heater too.
MITEY-ONE FEATURES:
1. Pressure: 100 PSI (on demand)
2. Vacuum Motor: 3 Stage Epoxy Painted /100cfm
3. Tanks: 3 ½ Gallon (Solution/Recovery) View-Thru
4. Power- Spray Feature: Apply deo./traffic lanes
5. Hoses: 15' quality vac/ PSI hoses w/swivel cuff
6. Wand: Select either unit w/ stainless Detailer tool, or 10" Professional stainless steel wand. (1,000 psi rated)
7. Wheels: 8" Rear Rigid x 3" Swivel
8. Specs: 20"H x 20" L x 13" W/ approx wt=32 lbs./ 9.5 amps/ (1-25' cord)
They seemed to be a pretty stand up company with a long time in the biz
Thank You in advance!
Jeremy
How big is it exactly? Got pics for space comparison? Thanks!
