imported_RaskyR1
Thanks for the ideas so far guys....keep them coming.
I took some pics of the garage today. Obviously there was some misunderstanding on what was currently there and as you can see it was an older existing building which currently it has 2 large doors on the 40' wall. The floor slopes towards those doors so the trench drain will be placed just in front on them and run the 40' span of the garage. The plan is to vault the ceilings and place a larger door at the 20' end making it easier to pull his truck and or boat in. The side doors are in great shape and seem well insulated, but he is looking to see if there is anything he can do to minimize heat loss from them. They likely won't be used much, if at all.
Some pics:
This is the end where the new door will go in.
Water will likely come in on this wall along with a sink in the corner.
I figured (9) 8' HO T8 fixtures should be sufficient (running them length wise in 3 rows of 3). The walls have a nice plastic paneling on them now and the ceiling will likely be covered with the same stuff. I suggested wall mounting the Cam Spray at the mid way point with a hose recoil. A bench on the 40' wall along with some storage cabinets would be nice as well. He is going to talk to the builder about placing the air compressor outside in some kind of an enclosure too if possible. I think it would be nice to have 2 air coupling points on the 40' wall, also with hose recoils.
Sounds like he is putting in an air exchanger too.
Some pics:
