Heavy swirls and the power of SSR3
blkyukon
This is a friend of mine's car that I've been procrastinating doing...finally bit the bullet and tackled it.
03 Black Highlander
Products used
PC
SSR3 - Cutting pad
PO85RD - Polishing pad
4Star - UPP
Souveran Paste wax
Here are the befores:
:bolt
Nothing was touching these so I decided to break out SSR3 and a cutting pad..finally getting somewhere, with very little hazing.
The thing to remember with SSR3 is DO NOT prime the pad with a qd or water...Priming the pad will lead to heavy hazing.
Here is the hazing left from SSR3 up close:
Here is after PO85RD - polishing pad:
Here is another before and after:
This was a 2 day process and here it is after UPP and Souveran paste wax:
Not a 100% perfect...but a 100% better!
Amazing!!!! The awesome part is you got those results with a PC!! I would have cried the whole time if I had to only use a PC for that car... :( Excellent job
what did you mean by do not prime the pad?
Prime it with the polish or with a squirt of qd?
by the way that is a SICK job, nice work!
Jim
Thanks everyone...It was a huge job and the owner was floored by the turn around.
Jim
Sorry I changed it...Don't prime it with a QD or water. Also change or clean pads often when using SSR# it clogs pads quickly which can also lead to excessive hazing.
DiPsAuCe said:
very nice.
why everyone keep saying "can't beleive u got the result like that witha pc"?
is a pc not that good?
PC is great. Just some defects take a rotary or wet sanding to fix. PCs can fix alot of things, sometimes it just takes a loooooooooong time.
Holy moly you had your work cut out for you! Very good results. I don't want to think of how much time you put into that Highlander.
