thedetailer
David, Can we use this with LC pads? Will we still have great results?
thedetailer said:David, Can we use this with LC pads? Will we still have great results?
DavidB said:The CCS and other "complex" pads from LC are a bust with UNO.
UNO likes a pad thickness from .75" to 1". On PC/PCXP/G110/UDM, UNO likes a pad between 5.75" and 6". On the Flex 3401 and rotary tools, UNO likes a 7" pad. The only wool pad on the market I recommend is the Meguiar's Solo Light Cutting Pad:
Meguiars Solo Wool Light Cutting Pad 7 inch
DavidB said:Flat LC pads are fine.
The CCS face does not help UNO. UNO likes em flat! None of the fancy stuff.
IC3DT3 said:So just to be clear. Regular flat 6" LC pads like the ones I bought from Detailed Image will work with UNO on a Flex DA. Correct or no?
Wknd Dtlr said:1. I am looking to detail an '86 white 300z for a friend at no charge to help them out. I have not yet seen it but I think it is single stage. How does this product work on SS paint? I saw earlier in the post it can be used on SS but the majority of the info appears to be slanted to CC.
Wknd Dtlr said:2. I will not be wetsanding this. In this case, will the original PC work ok? Couldn't quite tell from the posts as some posts indicate you need a minimum of a PCXP. I am an enthusiast so I am not really considering a new polisher purchase right now. Also, I will get the highest correction possible but this is still a DD for them it won't stay that way for long. I just want to test my skills as I have never done a car this old before. Also, I only have about a day or so for a full blown detail so this seems like it would work well with my situation.
Wknd Dtlr said:3. Any chance I can cheat and use my 5" backing plate or is that a no-no?
Wknd Dtlr said:4. Can I get by with two pads if I clean the pad after each panel?
Wknd Dtlr said:5. Are the pads, polish, and backing plate in stock and shipped out fairly soon after orders are placed.
Wknd Dtlr said:Thanks for your help on this!
Showroom Shine said:Well I bit the bullet pretty quick on this one too. I have had the HD Uno for a month. I have used it under various circumstances and conditions. From scratches to swirls. My take and this is only my opinion. The product smells a bit like Menzerna. Maybe alot of these products smell similar. Fortunately I am able to purchase in small quantities frequently almost any product that hits the market. Big Guinea Pig! I have a little bit of alot of stuff. I use various products for different situations and colors.Some work better than others,some are alot of Hype! You live and learn,and I think the majority of us are addicted to buying the new stuff. The natural high from the package arriving! But it's ok to get a Buzz this way!
superchargedg said:Hey David i have the flex da and only have the original backing plate.Are you going to make a larger pad then the 5.25 size.
bogi094 said:How does one use this pad? Would one pad do all the work without cleaning it half way? Would I have to prime it before using it? If so with what?
And how long- ho many cars, can I do before the foam is bad?
Thanks
BigAl3 said:hey thomas... in your experience, how would you compare HD Uno to #105?
