HD Speed fillers or no?
As a 1 step product, my last concern would be whether SPEED hides or not. Pretty sure the OP isn't getting top $$$$ for the detail, the objective is a fantastic looking finish. And Speed provides it.
OP - while you maybe impressed with SPEED, I think it is the RUPES that is providing the amazing correction for you.
I don't doubt the Rupes is doing a lot of the work. What led me to ask about fillers was the fact that I didn't work the product very much. Did 3 section passes in no more than 30 seconds and was impressed with the results. So I just got curious.
ill probably do some experiments next time I use the combo and see what results I get after an IPA wipe, slower arm speed, more passes etc.
I used to work for 3D - so I do know the product pretty well. if you happen to have a pc, try the same. See how the finish looks.
You can also use an aggressive compound with a soft finish pad - one that doesn't hide: with a soft pad it will.
As I said, and I realize that it is good to know, with a 1 step, the objective shouldn't be removing swirls vs hiding them. If that is what you are after, simply use hd adapt and apply poxy on top. In my book, speed doesn't hide.
