HD Polishes?
thomasdekany said:
Still the same, less is more philosophy, for both products. UNO can still do 3 in 1 duty. It also comes off easy. However, using non rotary polishers, on flat black paint you need a less aggressive product to eliminate the very tiny "pigtail" marks. Use UNO on a metallic black paint and UNO is the only product you will need.
Having said that, the new HD POLISH is an amazing product. I spent 5 days on a black Mustang and it was the best looking finish I have ever produced. Thanks to UNO, and POLISH.
Thanks Thomas!!!
Jamie 80 said:
As far as applied pressure, UNO as a 3 in 1 I am guessing you are playing around with speed/pressure to finish out properly with one pad. Or maybe cutting with a more aggressive pad and finishing with a less aggressive pad, using UNO as your only product?
I use UNO on most of my jobs since i got it about a week ago i have been using one medium cut uber pad from start to finish, worked phenomenal!! Cut my time in half easily. Highly recommend UNO , I have speed on the way next week when its released ill you know my results,
David Fermani(I trust big time) told me that UNO AC will work as it's supposed to in direct sunlight on a hot panel. That's a HUGE benefit for me!!!!
Can you elaborate on which Uber pad you used and your successful technique with UNO (which I assume is V4)?
