imported_Tuscarora Dave
one time I painted a 75 F-100 with a roller and exterior flat black (true story).
But on a serious note I have painted a few cars in the back yard. the problems I have encountered with doing this was dirt or dust blowing into the wet paint. I was able to wet sand and polish them out though. I am talking beaters though. I have painted a few in the booth as well and would suggest cleaning your work space very clean and leave the floor wet with water and don't stomp around in the water, for sure ground the car with jumpers to a water pipe or a ground rod. Pre clean with prepsol or equivalent before doing any grinding on dents prior to filling. If you don't you will grind wax or oils into the metal and end up with bad fish eyes and bondo possibly falling out before the 5 years you want to keep the car is up.
I would suggest that you use the pre cleaner on any panels that you accidentally touch with your hands because finger prints cause fish eyes and other adhering issues. and make sure you get a few tack cloths to pick up any dust before you spray your base and clear. make sure that your paint flashes between coats. and always paint the hard to paint areas such as wheel wells, window pillars, bumpers and tail light and headlight areas first then single even overlapping stokes from front to back going past the end of your work on each paint stroke.
I would say without a booth it would be nearly impossible to do without getting a small amount of dust or dirt in the paint. Beware of the fact that if you do this in your garage you will need a respirator, maybe a tyvek suit, hair net or painters sock and cover anything in the garage with plastic including the walls because you will have overspray and a lot of it. If it were me I would just prep the car, buy some quality paint and have a pro do the painting. all the prep of the space you will work in will probably take more than a day. and what about the local ordinances. is painting your car at home even legal.
These are just a few thing off the top of my head, I am sure it is not a complete reccolection of how I painted a car being it was before LPHV equipment was mandatory.
Hope this helped, Good luck
