Beemerboy
Just One More Coat
The steps I have listed were for use on an auto clear coat...
I was also talking about using a small amout of product, not pouring the whole bottle on it.
I agree CLR is an aggressive method, but the reason for rinsing off the CLR at the end is to neutralize the PH.
I have worked in Bodyshops for over 8 years.... blah blah blah.... I haven't had a problem with it yet:inspector:
But all in all, this is what works for me. If it's not your cup of tea, sorryassout:
You don't need to have an attitude about this with me...I didn't call your process bogus..its an extremely aggressive product on a very soft clear coat..its like suggesting lacquer thinner to remove overspray...I've done it, but you have to understand every step and then how to correct what the LT has created.
If you followed my link we had a pretty good discussion about CLR and paint, and it was deemed to aggressive for the guy that did...even the web site for CLR says not to be used on painted surface...That dosen't mean that you can't...but I would bet that the result is that you end up having to do some pretty good clear coat correction after..where as a milder acid will do the same but not stain or haze the clear..or run the chances of running the clear.
The one thing that makes this site a good info source is that most everyone gives advice on process that they have used or tried...I got the feeling that you had not used this on a car...and by the fact that you posted it some new person might read this run out and pour some on a car and find out that it did take the WS off and ruin his clear in the process
Just for the record a acid based wash is something that I plan on using but not those that are found in CLR..
Also...if you want to throw number of years and experience into the mix I have over 30 years of hands on detailing experience.
These water spots I had a good idea how to get them off..just wanted to see what others in high calcium water areas do!
