Anthony Orosco said:Much nicer weather right now eh?
No, cooler weather means winter and shorter days are on the way.
Honestly, you have no idea how much I really despise winter.
Scottwax said:No, cooler weather means winter and shorter days are on the way.
euro said:Wow, Wow, :wow:
It looks brand new.
Whoever owned that beauty before should be shot...immediately.
Picus said:Fantastic work. Really; the attention to detail is second to none.
justin30513 said:Im liking this GR40.
Where can I find it at?
Amazing work.....cant wait to get some of the new formula!
G35stilez said:Ditto.
I love all the dye work and steaming the engine. Could you elaborate a little on which attachments and such that you use? I have a Daimer Pro model now and want to expand my uses a bit with it.
Thanks.
RTexasF said:Absolutely above and beyond the call. You make me proud to be from San Antonio. Top notch work like yours is far from the norm there.
Accumulator said:[INSERT usual :bow regarding Anthony's work here..]
Anthony- I always learn something from your posts (GR-40 huh?) and it's a pleasure to see how you bring back cars like that.
I look forward to hearing (and seeing) how the A8 goes. Not that *you* need advice from *me*, but be sure to tape off the clear anodized aluminum trim. That (sorta-fragile) stuff is a real Achilles' heel being adjacent to the hard clear and it's rare to see an older A8 where it's still intact. Some of the inset aluminum trim on the newer A8s looks like it'd be a bear to mask off properly.
Anthony Orosco said:..[The Audi A8]..has hail damage on that trim so it will be replaced...
..Don't use high pressure and the small nozzle on carpet. If you feel you must use the small nozzle use only low pressure with the steamer...
mgm121499 said:Anthony,
(I've worked with a sample of the new OC via Cyclo, PC, and Metabo).
IMO, Optimum Polish is one of THE BEST products/values on the market,
but the new compound seems 'rushed'.
