Gyeon Wax is quite slick...not Gyeon Syncro slick but wax-ish slick. I`m still waiting for it to rain on the 3 vehicles I put it on 10 days ago![]()
@budgetplan1 @coating=crack How do you find the gloss/look compared to Cosmic?
Sadly I get nowhere near that with polish angel LSPs. I`ve found 4 reset washes are sufficient to remove any visual trace of Cosmic from a fully decon`d, panel prepped car with a coating applied. How do I know it`s gone, I don`t for sure but it`s water behaviour is very unique, as was my base coating of cancoat, so that gives a reasonable indication. It fares marginally better on a standalone basis, but let any form of (even neutral) snow foam dwell on it and the top top performance lasts a fortnight. Avoiding even the neutral free rinsing snow foams it`ll do 7 weeks tops before it takes a real dip.. and that`s wrapping it in cotton wool, which is a bit ridiculous to have to do. Cancoat, in comparison makes a mockery of the expected durability claims and don`t get me started on that snake oil Primer Spritz at £59 for 200ml.Yes as budget said its pretty slick. With smaller beads and a little less water in total i would give a slight edge to Gyeon wax after looking at picks.
Height of beads down to same.
I get about 2-3 months where i’m happy with Cosmic. It still 75-80% their but at that point beading is at levels of other basic sio2 sealants.
I used to love Cosmic, it`s so addictive to use it took me quite a while to just leave the car be and stop with the regular top ups.. That`s the dangerous hamster wheel you get on with PA stuff, it doesn`t last and it`s saving grace is that it`s so damn easy and addictive to reapply. Once you get wise to viscous cycle as I have recently, you realise that it`s gains are marginal. There are cheaper products that do 95 percent of the same thing. And it`s fundamentally grabby.. once you`ve tried a slicker alternative it`s something difficult to un-feel. How much slicker is Cosmic than BSD, not a tonne. Doesn`t smell much different either.....
It`s look is unique, but not overwhelmingly so.. no jetting effect whatsoever but optically very clear so it is fantastic on metallic paint, less fantastic on flat blacks etc.
Cosmic is one expensive QD... speculating but I`m not sure you`d get the 7 months durability they suggest it will give on a Sunday driven garage queen. People will point fingers and say it was my routine etc etc... I physically altered every bit of said routine, spending a lot of time and money in the process... to come to this overall conclusion.
As always YMMV.
Sent from my LYA-L09 using Tapatalk
I haven`t used a snow foam with a pH of over 7.5 on Polish Angel LSPs in at least 8 months as quite literally that is flushing your money down the drain.
Even though it`s chemical resistance is pretty poor for a product of it`s type, this isn`t my issue here.. it`s that actually regardless of maintenance product pH it`s just not durable and PA`s claims (esp in the case of Primer) are simply delusional. I do a lot of testing and have multiple moving and static panels which I monitor and maintain (not quite the size of Budget`s fleet mind!!).
Forget driving, forget road film and salt, forget tree sap, iron fallout, limescale deposits, tar, pollen which can all cause noticeable degradation. I have one test panel which much to my wife`s annoyance sits in our back garden not exposed to anything but dust, rain and sun. I wash that panel every week before doing my own car, I`ve repeated the test 3 times (including with different polishes, different panel wipes, 2 or sometimes three coats, brought the panel inside to cure etc)... all 3 tests showed the initial performance to drop away after 4 Reset washes, water starts to stick and beading turns to fast sheeting at the 7 or 8 week stage.. I could list every permutation, using different bottles of Cosmic (both under 6 months old) etc etc. but I`m conscious that I`ve already sidetracked the thread more than enough!
Just know that I`ve written tens, maybe hundreds of posts about how good Cosmic is, so this is more than a bit of a climbdown. I`ve no issues admitting when I misjudge something, in the case of Cosmic I knew it was terrible against alkalines, it just took me stop the topping to work out that it doesn`t last full stop, and when you try a much wider range of LSPs, Cosmic actually feels grabby in comparison.
Re. visuals... far from flawed, suggest you do some digging on Detailing World (vs. BSD, Overcoat, OSM, CarPro Lite and others) and tests from Car Craft comparing vs. BSD, Bowdens and Zaino... these tests really remove the subjective nonsense where a large proportion is what you want to see. While I was being deliberately flippant with my comment about Cosmic effectively being an overpriced BSD, bar usability and perhaps a tiny bit less grab, I don`t think they`re a million miles apart.
https://www.youtube.com/watch?v=3EzZ9nelfhk&t=795s
In terms of what I am using now.. I`m not really committed to any one thing and testing lots of different stuff. I received a 100ml sample of IGL Premier yesterday for example and liking the results so far. There are a couple of other European and UK based toppers which I can`t say much about at the moment but to be honest I`ve found coatings, even Lite coatings to just work much better untopped. Unless the coating has a noticeable deficiency in one area, or the looks fade over time.
For a really good all round product like Cancoat for example, no topper will improve the look, self cleaning or hydrophobics, so unless it`s bringing something else to the table that Cancoat isn`t known for (slickness for example) I actually found myself questioning why I even bother searching for the holy grail of toppers, when it`s so easy to apply a lite-coating periodically! Besides, weekly or fortnightly application (without full decon) of anything other than a QD leads to diminishing returns (reduced gloss, reduced LSP adhesion, in some cases making chemical decontamination more difficult).. I decon my car 4 times a year so if I was in the cycle of topping my car, I`d ideally want that topper to last those 3 months... we all have different standards and expectations but Cosmic struggles to show any reasonable performance past the 2 month mark, hence why it no longer fits my routine.
If you`ve got different results, lucky you. Please tell me what I`m doing wrong![]()
