Gyeon Q2 CanCoat
I`d been testing Moonlight against Cancoat last year and generally found Cancoat to maintain good performance for longer. Moonlight doesn`t quite have the initial crazy beading but with top ups it can do the 11 months it claims. It`s a bit slicker and nicer to apply to be fair.
Initially yes, the beading is way nice on Cancoat. After about 2-3,months though comparable. Cancoat got toppers and i got about 12 months
At six months i’d say performance wise this combo could be slightly better. Not much. This car didn’t need a decon.... just did it because i have a gallon if BF iron remover. I also just used Reset and not the Alkaline soap i normally use because i felt it didn’t need it.
The car i had CC on definitely needed it at 6 months. With it tho performance came back.
If i were looking for out right self cleaning and protection i’d say this combo winning in light category. I’m also guessing this is mainly Moonlight performance as i applied Adam’s GSC wrong. Applied and wiped almost instantly as it rainbows fast. Read on Adams shoulda let sit for minute or two.
Overall my choice would be Cancoat as I feel it’s molten glass appearance is one of my favorite from an LSP.
Another factor though is Moonlight last longer in bottle. It was over 2 years old when i used it in April.
CanCoat was jelly at 13 months
Good to hear you`re getting performance from both. Moonlight with Cancoat on top is a really good combo to try, Budget inspired me with his Overcoat Cosmic duo. Looked just that bit more special (to me anyway).
My bottle of moonlight actually gave up far quicker than the cancoat! Suspect that was my fault as some of the product had solidified at the cap so it may not have been fully air tight.
When you apply 2 heavier coats of cancoat (lay it on thick and give it a bit of time before wipe off) it only adds to slickness and durability.
Sent from my LYA-L09 using Tapatalk
Thanks for the feedback coatings and atbalfour.
i`m very happy with my coatings but it takes alot of effort in my situation outside. Cancoat is a better fit for me.
I`ve since read that Adam`s graphene spray coating it also not water based? Like cancoat and moonlight? Looks like another option next year.
3D as touch as well, never heard anything about yet. 3D is actually the more costly product.
What’s weird is my bottle is 2.5 years old. Looked it up. February 2019. I’ve heard the same 1 to 1.5 years.
Weirder is i have some CqUk3 from around the same time. Little left in a open bottle and it seems to be good too.
If you are going to top CanCoat, I`d recommend Gyeon Cure. Not only is it designed to work on Gyeon products and contains common ingredients, but when I used it on CanCoat, it preserved/kept the crazy beading/sheeting CanCoat delivers.
