Thomas Dekany
The attachment makes even the flex 3401 feel like a toy, not sure if you need it, if you want to emulate speed 4 on a da.
For me, lower speeds don't work well, speed 5 or 6 is what does it.
RZJZA80 said:so I guess using MF pads with the attachment isn't a good idea then?
gmblack3 said:I use DB and Megs MF pads with my flex small 3403 rotary all the time. I crank it up to speed 6 on the 3403 which is around 3600rpm. Not sure what that makes the OPMs.
RZJZA80 said:Good to know. I only asked because of the heating issue the MF pads may have (and subsequent pad failure) on a DA when the speed is too high.
gmblack3 said:Its kind of different on a DB. You dont need that extreme pressure when using a DB like you do on the GG to get effective cutting power. I still apply some pressure on the DB when heavier cutting is required, but nothing like with the GG.
The 601/105 1 to 4 mix goes on great with a 5.5" red pad and the Groits--so much faster than by hand and you can spread it very thin for easy removal.shortspark said:My Griot 6" should arrive on my doorstep any moment now, according to the tracking information. I have a brand new car and want to treat it as best I can. I like to use Duragloss products by hand but have never used them with an electric polisher before. The thing is I only seal my paint once every six months so I am pretty certain that it will outlast me twice over!!
pwaug said:The 601/105 1 to 4 mix goes on great with a 5.5" red pad and the Groits--so much faster than by hand and you can spread it very thin for easy removal.
