Glaze and Sealant?
FordFan2009
I am waxing the wifes car tomorrow and want to try out some new products I found from this site. I don't have a PC yet so no correction. It's dark metallic blue and has some mild swirling. I want to use DG 101 and then 105. However I know this won't hide the swirls verywell So I want to use a glaze. I have some #7. My question is, Can I apply the glaze over the 105 and seal it in with AW? or will the 105 bond to the #7 If I layed that down first? I do have some M105 but don't really wanna rub that out by hand so I want to experment with some glaze till I can buy a PC.
Skip the glaze. Sealants and glazes don't work well together. If you want to use a glaze, you'll need to do it before any protective coating and then finish with a wax, but even then, durability lessens greatly, because of the glaze.
DWG is one of the few that can be applied under a sealant. No oils in it. It is acrylic based and has no cleaning abilities. It can go under a good sealant like DG 105 or even on top of.
