Gift Registry Giveaway
@Ray, I`m having trouble adding products to my registry. I added four the other day, but need to add a couple more things to pass the $100 mark. I click `add to gift registry` and then it redirects me to a page that doesn`t exist after I click either `continue` or `view registry` and the product doesn`t get added to my registry.
Please advise
Please advise
had the same problem...
PM me your email addresses and I`ll check your accounts.
There is a bad redirect somewhere, and only on certain items for me.
Here`s the link that it tries to go to after trying to add an EXO V2 30ml to my registry.
attachment.php
attachment.php
It would appear to me that it only happens on items where there is a selection of two sizes that you can pick. For example, if you add the gallon of PB Typhoon it works fine, but if you go to the smaller size where you have the option of both, you get that secondary page where it asks you add the item, then it doesn`t work. Hope that helps.
attachment.php
That is correct. I made a similar post a page or two back noting the same issue. Add both sizes and it will add the larger size into the registry.
