Ghosting or oxidization?
stoppy
Hi there,
I am still pretty new into this detailing game however done some good repair on my old black BMW 330. Now my new challenge, 1995 "Guards Red" Porsche 968. The paint is pretty dull and has some spots like this:
attachment.php
attachment.php
Kind of looks like hard water spots. I have used some M105 and M205 with my Griots DA but still remains. I believe this car to NOT have a clear coat as I think it was resprayed at somepoint during its life. Also I do get a good amount of red colour on the green pad I use.
Q: I was looking at Sonax Paint cleaner. Think this might be a good option for this correction. Thoughts? Any other ideas?
Thanks for any help. Forum has been very helpful.
It sure does look like water spotting to me as well. I`m going to agree with you and say it`s single stage due to the color transfer you are getting on the pads.
Any other areas of this or just the ones you posted up?
Watch the edges with a larger pad on that area as you could strike though. Tape it up before you correct anymore.
What pad are you using and what speed on the Griot`s?
And did the 105/205 make any difference at all?
We will get you in the right direction!
To get longer section passes with M105, give the pad a spray with a quick detailer.
Sent from my SM-G955U using Tapatalk
Hi there,
Thanks!
This is the only area like that, but you can see here from the side mirror how faded paint is
attachment.php
Pad i was using was a green LC. 6". I only have a 6" DA which makes it hard for me to get into this spot.
105/205 different a little, but not a lot.
Would Sonax paint cleaner maybe clear some of this up?
Thanks again.
If you have done that much on single stage and those defects remain, leave it alone. There are things that cannot be fixed! Measuring with a gauge will tell you for sure.
Porsche stuck with single stage for Guard`s Red for a long, long time, so just because it`s ss that doesn`t mean it`s a repaint.
Stoppy- Please don`t take the as an insult, but are you sure you`re ready to tackle this car? Is it yours, or does it belong to somebody else (I sure wouldn`t learn how to work old oe single stage by doing somebody else`s Porsche with weird issues). I`m with Mike lambert on this, "first do no harm". There really *are* things that ya shouldn`t try to fix and IMO working on cars like that makes an ETG (and magnification) pretty much mandatory.
IF you do want to proceed, I`d do a small area *by hand* with the M105, inspecting contantly under magnification. Don`t try to rush it, let that little area (I`d probably work about one square inch) take as long as it takes for you to either get the results you want or to decide that enough`s enough. An even safer approach would be to use the M205, but I understand that most people won`t want to put in the time/effort for that.
EDIT: I don`t know from Sonax Paint Cleaner, but maybe you oughta try that test-spot with it instead of the Meguiar`s stuff.
Hi there!
Thanks for the feedback, much appreciated.
It is my Dads car that I am working on. Appreciate the concern, really can`t answer you to be honest! It looks manageable however we`ll see.
Will update this thread on progress (if any). Again thanks for the help
Try the 205 on the mirrors to see if you can remove a layer of dead paint to bring back the guards red paint. I`ve seen worse fading on guards red as they will turn pink.
Also as Mike mentioned, if you have access to a paint thickness gauge, please use it to see what you are dealing with. If not, let us know the area you are located in and someone on the forum may be able to take some reading for you!
Keep us posted...
Hi All!
Sorry for the delay on this one.
I hit both the mirror and the roof line with 105 followed by 205 with orange LC pad running griot around 4-5. Few passes with some good pressure and this lifted and paint is great.
Thanks for the help!
stoppy- Ah, glad things turned out well! So it *did* clear up after all with a bit more work?
Hope the owner takes precautions so you don`t have to get aggressive with it again!
