Garage security blooper
KenSilver
The other day I left my house in a hurry, pressed the remote as usual and didn't look back.
You guessed it - when I returned about 20 minutes later, the garage door was up. When I tried again, it went back up and I had to lube the center rail to get it to close.
Lucky my garage faces a bunch of other houses in a reasonably well trafficked street, so nothing was stolen. But it was a big worry... I have my tool chests, machinery, tv and so on in there - all ready to be taken in a whim by an opportunist who saw this open garage.
How does everyone secure their garages? I have a motion sensor alarm connected to the rest of the house, but everyone knows that no-one takes much notice of house alarms these days because of their unreliability.
Save tying everything down in lockable compartments, what can I do?
And wouldn't it be great if the garage door texted my cellphone when it was open for more than 5 minutes?
Ken Silver
1993 Mercedes SL500, 1991 Daimler (Vanden Plas), 1991 Miata MX5 ... Finish detailing them, then start all over again...
I have the special James Bond Lotus Style Garage Protection System. Upon unauthorized entry the entire property will explode. :D If I can't have my garage and the stuff in it then nobody can. :bigups This was my last house that got messed with.
...stupid cat... That'll teach him to jump in through the window. :eek:
Happened to a friend last month. Got home, and all their power tools were gone, including the PC and all the pads. :eek:
If you have a key operated switch that you have access to outside the garage controling the automatic opener (as most by me do) keep in mind its just a set of electrical contacts normally powered by 12 volts. Meaning that a water pistol properly aimed ( or a hose) will make the contacts and your garage will open unless it is bolt locked.
How do I know, I lost my key and the locksmith showed me, he claims all the kids know it, new one to me.........
Bob,
That garage door closer looks like a great idea! Exactly solves the problem, and it's not as wasteful as Jngrbrdman's exploding system :)
By the way, nice Mustang. My tax consultant has a 2003 model and he's hooked on them - he's had several.
Garage security? 2 words. Big dog.
To deter the casual thief, you can put up signs such as "Beware of Dog" and alarm company signs, even if you don't have either. For the professional thief, well, if they want it...
If you're in good with the neighbors, you could start a neighborhood watch. It doesn't necessarily have to be active (patrols and such), but the street signs posting such can deter casual thieves. Local police can give you more info.
For automatic garage doors, I'd disable any outside switch/key that activates it. Make sure your system has a "rolling" code for your remote. Deadbolts on all exterior doors. And maybe frost the windows to your garage so people can't just look in and see your toys (blinds can be left open, and unless fit perfect, can still allow a limited view inside).
Dave
Good points Dave. Particularly the rolling code. Thanks!
Ken Silver
1993 Mercedes SL500, 1991 Daimler (Vanden Plas), 1992 Miata MX5 ... Finish detailing them, then start all over again...
KenSilver said:
Bob,
Ha ha! Not as wasteful! :rofl
Would that have worked in your case, though? It sounded like your door was jamming in the track causing it to go back up?
Hearing these stories, now I don't feel like such a goob for always sitting there until the door closes all the way (though I worry it will freak out and go back up on it's own as soon as I drive away).
Yep, the center guide still had old grease on, plus quite a bit of wind at the time which acted as an obstruction/ damper causing it to open again.
That episode has taught me a lesson, and like you I sit there until the door clangs closed and stays there. To save time we can always do up a seatbelt or look for pimples in the mirror while it happens.
:wavey
I'm usually a stickler for closing the garage door. One nice day I went to the hardware store and left the garage doors open, after all I was only going to be gone a minute. Sure enough, when I returned, my compressor was gone. Now, the doors get closed EVERY time I leave or even go upstairs for something. My next compressor will be bolted to the ground and not a portable one.
:grrr I will sit and wait for the door to close completely and always keep it lubed up. Live and learn I guess:wall
Day to day is tough because the garage doors are the weak spot. I do, however, put padlocks on them and disconnect the electric openers when I leave for the weekend or go on vacation. I always lock my cabinets just to make things harder just in case!
My windows are glass block which let in lot of light plus are very secure.
And don't forget to lock your cars!
:xyxthumbs
Great thread, everyone- thanks for the tips!
I won't have the garage until April, but am already looking into security measures.
And if all else fails....Make sure you have "replacement cost coverage" on your contents and you insurance premium is paid.
It varies fron state to state but I have not found a significant difference in premium by keeping the deductible down around 250 or 500.
Since I retired, I know I could never afford to replace my beloved Lingenfelter, so I'm quite anal about making sure the garage door is closed. I bought a device made by Liftmaster that is wireless and has LED's that indicate if the door is up or down. It's mounted on the wall by my bed! (also a great way to tell when the teenage son gets home at night, you can see when the door opens and closes). Another thing I did was to replace all our push button transmitters with keypads that normally mount outside the garage door. Now if anyone breaks into one of our cars, they can't simply steal the transmitter and help themselves to the garage because the keypad has like a jillion codes available!
I have learned to hit the remote as soon as my hood is out from under the door, and by the time I am to the end of my driveway it is shut.
There have been a few times when snow has accumulated under the door , and the door reopened itslef.
One thing I have learned is that If it opens back up, and the light flashes, something passed through the eyes ( Usually my dog, I have a detached gar, and when I take the dog out with me, she sits under the door purposely so I can't close it via remote she "toys" with it, moving back and fourth so she makes it go back up and they said dogs were stupid?).
Interesting idea. Our door has a little switch to turn it off, so we just remember to do that when coming in. However, a code thing would work better in case we forget.
The Aurora has Home-link, so I don't think I'd ever put an opener it it, but then I'd never leave it out at night either... ;)
:xyxthumbs
That will not work for me. :( 2 of my 6 cars are convertibles. The classics are very rarely driven so the batteries are stored in a separate location on the property. :bounce
Another vote for big dogs and neighborhood watch. :xyxthumbs I have 3 - a Great Dane (~185lbs), a Rottweiler (~125 lbs) and a boxer( ~90lbs). They are very friendly dogs to people they know but very, very, very protective of their family and their turf. One of my neighbors is a retired couple that watch over things when we are gone during the day and our handy man dog sits when we are out of town. :cool:
