RedlineIRL said:
I know that the T rating is an idication of the bulb diameter, but does the higher the T rating of the bulb mean it will provide more light output? What about bulbs, is there a certain kelvin rating that most prefer for detailing use, or is it just more of a personal preference?
The T5/T8/T12 rating just has to do with the form factor of the fixture and lamp; the wattage and other factors determine how much light is produced by a given setup. Generally speaking though T8 is the current industry standard and will be the most widely available.
Generally the color temperatures I would try to stick to would be 5000K or 6500K... I use the 6500K myself. Be sure to look at the Color Rendering Index of the lamp(s) you buy as well -- the higher the CRI (closer to 100) the better to ensure that the color is as accurate as possible. All of mine were sourced from Home Depot:
Are the dual fixtures that Home Depot and Lowes sell any good at all? Or are there any places online that sell better quality for a similar price?
The Home Depot/Lowe's fixtures are generally alright; but do your homework online to make sure you can't find a better deal.
Right now there are 4 four foot fixtures, 2 mounted together lenghtwise on opposite sides of the garage. Here's the ideas I am thinking of
Replacing all the fixtures with something more powerful and better bulbs and mountng them in the same location, connected together lengthwise on opposite ends.
or
Buing 2 8 ft fixtures and mounting from the celing lengthwise on opposite ends, and going with 2 8 ft fixtures to mount width wise above the front end and rear end of the parking area.
If what you have now are T12 fixtures, you can easily retrofit them to T8 by just replacing the ballasts.... the sockets for the actual lamps won't have to change. It's cheaper than replacing an entire fixture. You will however probably want to add some additional fixtures beyond what you already have.
I don't know, I'd have to see some pictures of others setups to really get an idea on how to do this best without having $500+ tied up in all of this:think:
I've got around $450 tied up in my lighting setup, including the conduit, wiring, and outlets:
I'll grant that in many ways my shop is a bit on the "overkill" side, but I wouldn't want any less lighting either. Since there is a lot of "stuff" along the sidewalls, I have a single T5 fixture that remains loose so I can move it around to light the sides of any project I'm doing:
Everything aside from that one fixture are all standardized to 48" T8s. Cheap to buy, easy to find, and easy to transport/store.
