imported_RedlineIRL
I am working on doing some improvements on the new garage, and one of them I am considering is insulating the garage door. The current door is a little bit older model before insulated doors were the usual standard. I used a laser thermometer and the metal door from the inside of the garage was reading about the same temperature as outside, so its definitely allowing the cold air through.
I was looking at Home Depot and came across these DIY garage door insualtion pannels
Garage Door Insulation Kit-500824 at The Home Depot
To do a 2 car garage, looks like I will need two of these kits. So I'll have around $120 tied up in this if I go this route. Has anyone used a similar type of insulation on their garage doors on here? I was wondering if these will make a noticeable improvement before getting them
. At least you did it the correct way. We have had contractors and owners add wood to the front of their doors and wonder why their doors don't operate correctly.
