RaskyR1
Rasky's Auto Detailing
Flashtime said:Very, VERY, nice work! Yeah, 40 hours sounds about right.
Whatever the painter told you about shooting only 2 coats is BS. It is a general
rule of thumb to shoot 3 coats if any amount of sanding is going to be done.
This is true for all the clears I've used and heard about; this should be obvious.
Most products shops only shoot 2 coats of a high solids clear, basically to save
time. I've been telling folks getting stuff painted to ask for 3 coats; pay a little
extra if needed.
However, every painter is different. Even with the same clear and conditions,
one guy's 2 coats can be similar to another guys 3 coats...
And with all the sanding/polishing done, I'm pretty sure there isn't adequate
amount of clear film now. At a minimum, there should be 2 mils of it. I don't have
a paint thickness gauge, but i do know the approximate build per coat of the
clear I'm using (slightly over 1 mil per coat of a 52% solids clear)...
She's lucky, she has you to maintain it! That can be all the difference for
durability...
Thanks!
Apollo_Auto said:Yup you'd better get some serious nubbinz fer dat! The wet sanding looked great; nice and even all around! And of course the end results... Rasky standard!
LOL. Thanks Jesse
