Full wet sand n' buff on '05 NBP Acura RL, by Rasky's Auto Detailing
RaskyR1
***Let me first start by saying that this car underwent a full repaint and that this is NOT something I recommend you do on a factory painted car to remove orange peel.***
This is actually my fiancée and the car, which got hammered with over $9k in hail damage! My father works at the body shop where the work was done and I offered to do the wet sanding and buffing in exchange for having the bumpers and side moldings painted….that and I didn’t really want them doing it anyway. :D
Originally I had planned on doing the work the same week I picked it up knowing just how hard these newer high solids clear coats can get. Unfortunately things kept coming up and the job kept getting pushed out. It was about 4-5 weeks time between when it was painted to when I started the work…not good.
As my past experience has shown, the clear was indeed rock hard! Probably the hardest I have ever worked on and my normal process for wet sanding had to be tweaked in order to work with this paint type.
Wet sanding process:
-3M P800 via DA with soft interface pad for initial leveling (I taped off the edges 1/16-1/8 away for this step since I wanted to avoid thinning an edge too much)
-3M P1500 grit via DA with soft interface pad.
-3M P3000 grit via DA with soft interface pad.
Buffing process:
- 3M Perfect-it 3000 extra cut rubbing compound via rotary and Meguiars Solo heavy cutting pad (cut faster than M95 and Power Gloss but left deep marring)
-Meguiars M95 via rotary and Meguiars Solo light cutting pad (removed heavy marring from the extra cut and picked up any pig tails I may have missed)
-Menzerna SIP via rotary and orange LC Classic pad (finished nicely)
-Meguiars M205 via PC7424XP and White LC Classic pad (removed any remaining buffer trails left behind from SIP)
-Menzerna PO85RD via rotary and black LC Classic pad (Icing on the cake!)
My choice of LSP was Blackfire Wet-Diamond.
Pre hail damage the paint on this car was actually like glass right from the factory. As you will see, after the car was painted it had some pretty serious orange peel, and to be honest, I wasn’t really happy with the way it came out. While my father did all the body work on the car, they do have dedicated painters at his shop so I couldn’t blame him in any way. They shop normally turn out top notch work. regardless, I didn’t feel it was so bad that it needed to be redone, but it definitely meant taking off more clear than I really wanted too in order to get it to the level it was at prior to the damage.
Before sanding I spoke with the manager about the paint thickness readings I found on all the new panels and wanted to ensure full paint warranty if I were to level the paint myself….which he assured me they would honor.
On with the pics!!!
Bad orange peel
Sanding in process
After pics!
Brinkmann
Halogen
Flash (I like how this made the blue pearl POP)
I drove the car about 30 miles before these pics so there may be some light dust on the car…
I didn’t keep track of my time on this job since I wasn’t getting paid to do it, but I'd guess I have around 40 hours invested….either way, I’d say the fiancée definitely owes me some serious luvin’!!! :dance
Thanks For looking!
Rasky
Awesome Work! How much clear did you have to level to get it looking good?
What kind of DA did you use for the wetsanding?
Superb finish.
What DA do you use? It looks like your effort really paid off... not financially though (pity) but you did a great job so pat yourself on the back!! :xyxthumbs
Did you need to do a process on the lights as well?
KaPow..
Edit.. beaten to the DA question by 10 seconds!! Replying at the same time! LOL!
Thanks!
Well I tested the hood first and went a little further on that panel to make sure I had enough paint to work with. I took off between 15-20 micron on the hood. I brought the car to the body shop the next day and showed the painter and manager the readings. I was acually a little upset they didn't put on more material on but the painter said anything more than 2 good coats and you risked solvent pop with the clear they used....not sure I buy that but what ever. I went lighter on the rest of the car though and my average PTG readings on the new panels are in the 95 Micron range.
I just used a cheap DA I bought a few years ago from Northern Tool...nothing special.
KaPow said:
Superb finish.
KaPow..
Thanks! I did get the bumper covers and trim painted out of the deal, and I also didn't have some hack at the body shop wet sanding and buffing my car either, so I feel I came out well. :xyxthumbs
I only gave the lights a light polish with M205. I may sand the head light at a later date to remove the pitting but probably not until we got to sell it.
gmblack3a said:
Great work Chad! The gloss level is off the chart!
I take it these where non-trizact sanding discs?
Thanks Bryan!
The P3000 was the newer foam Trizact disks.
I fianlly started shooting my pics in manual mode too....seems to have made a noticable difference in picture quality. ;)
Rasky,
well you know I love the look of freshly sanded paint. I must say you tackled this job to perfection! Outstanding results. A pain doing them full sanding jobs, but when finished its off the charts. Lots of gloss and very flat. I love it!!!!
dsms said:
Serious work! Beautiful job
Thanks Dave!
bufferbarry said:
Rasky,
Thanks Barry! It was definitely a lot of work but I feel it definitely paid off. Nothing like smooth black paint! :drool:
Darkstar752 said:
Wow, that looks absolutely amazing. 5 Steps AFTER the sanding though? Wow haha, that's a lot of work! :xyxthumbs
Thanks!
I probably didn't have to do the final step but I think it definitely added a little extra pop! ;)
Looks amazing.
Just out of curiosity...Was the hail damaged that bad that the insurance company didn't pay to PDR that? They wrote for a conventional repair? Or did they have to replace the damaged panels? Based on a 9k estimate, I'm assuming replace...no?
creina1221 said:
Looks amazing.
They did PDR what they could, but most of the panels that didn't get replaced still needed conventional work because of size and location of the dents. New hood, roof, trunk, and left front fender. ;)
MuttGrunt said:
WOW. Crazy gloss and clarity in the afters. Lots of hard work no doubt, but it all paid off HUUGGGGEEEE
Thank you! :)
Very, VERY, nice work! Yeah, 40 hours sounds about right.
Whatever the painter told you about shooting only 2 coats is BS. It is a general
rule of thumb to shoot 3 coats if any amount of sanding is going to be done.
This is true for all the clears I've used and heard about; this should be obvious.
Most products shops only shoot 2 coats of a high solids clear, basically to save
time. I've been telling folks getting stuff painted to ask for 3 coats; pay a little
extra if needed.
However, every painter is different. Even with the same clear and conditions,
one guy's 2 coats can be similar to another guys 3 coats...
And with all the sanding/polishing done, I'm pretty sure there isn't adequate
amount of clear film now. At a minimum, there should be 2 mils of it. I don't have
a paint thickness gauge, but i do know the approximate build per coat of the
clear I'm using (slightly over 1 mil per coat of a 52% solids clear)...
She's lucky, she has you to maintain it! That can be all the difference for
durability...
Yup you'd better get some serious nubbinz fer dat! The wet sanding looked great; nice and even all around! And of course the end results... Rasky standard ;)!
