gemini-s2k
Ok,
I'm beginning to get slightly frustrated. I'm no pro detailer and know it takes practice and experience to get to that level but I was hoping I would at LEAST be able to take hazing off my car. That, as of yet has not been the case - If not, it probably got worse since the last time I went over the car.
Rundown!
Car-01 Honda S2000
Color-Berlina Black
Products used - DACP, #80 Speed Glaze
and of course, the PC.
Pads - Meguiar's cutting pad and polishing pad.
To begin.
I went over this car 2 weeks ago with just DACP and a cutting pad to remove heavy swirls, at this point I was completly new to this and didn't realize I had to follow up with a polish with less cut to remove the marks left by DACP. 2 weeks pass I did some research and I went ahead and got Speed Glaze...
I washed, dried the car - Began working it again with DACP and the burgandy color pad.. made an effort to do small areas at round 5.. sometimes 6.. got most of the heavy swirls out the car..
Next up was Meg Speed Glaze and polishing pad! Time to remove that hazing right? Not..
I think my failure on this product and perhaps you guys can back me up once you read this story and give me tips is that I used TOO much product and didn't work it in as long as I should have.. I was getting impatient, it was night time and all I had was the garage light.. I could see the hazing on the hood but it almost felt as if CREATING some with the the glaze!
I never used the PC on more than 3.5 on the glaze, maybe 4 are you suppose to work this in as long/highspeed as DACP? How much product? When do you know when to stop? What speeds recommended for Speed Glaze?
I woke up this morning and pulled the car out the garage, hoping for the best.. I was amazed by the wetness of the car and how slicked it looked.. it looks awesome in shades.
Then the sun kicked in and I saw hazing all over the car, worse than last last time I did before even the Glaze.. but I was a lot more aggresive on the car with the DACP in hopes of having the glaze remove whatevers left..
HELP! I've spent over 200 dollars now in microfiber towels, products and the PC.. I know this all a learning experience and eventually I might actually be able to make a side buisness out of this but right now.. very frustrated..
Couldn't get a good angle but you'll see it in the last pic much much worse in direct light...
and yes those are perm scratches on my door.. has to be repainted =/
Rundown!
Car-01 Honda S2000
Color-Berlina Black
To begin.
