FMJ vs AIO + SG
ericlala
carcaresmart is carrying FMJ now but it is quite expensive. For the same price, i can get the klasse twins. I really cant choose because SG has the problem of being difficult to use for newbies and FMJ is praised in every aspect. but the klasse kit also comes with AIO so... which one should i get? I will be using OP as a polish and nothing in between
AIO+SG will last longer and protect better.
FMJ will probably look better and will be much easier to use.
So, are you going after looks or protection?
I used FMJ over AIO - excellent combo. FMJ holds excellent. A bit warmer than SG, and a lot easier to use.
Worth the dollars for me, plus, it will let you do a bunch of cars at 16oz. I used about 1-2oz per application for average sized car.
SG is NOT hard to use...lay it down thinly and it comes off just like any other LSP. If you put it on too thick use a spritz of QD and it will wipe right off... No issues.
ChrisNJ said:
After claying, how would aio > fmj > 845 work for winter? protection/looks?
If you were going to go that route, just skip the FMJ and use AIO and 845. Those two alone would outlast winter.
