Guess My Name said:Maybe even Mercury Vapor like the Gas stations use!!!!
I know someone who can get you Explosion proof ones if anyone interested. Gotta have at least 240 AC though 480 three phase preferable! They come 200, 400 or 1000W. Very white light very bright very large!!!!
jrush said:try neodymium bulbs. they are awesome!
Better yet is to use a metal cutting lathe - I would have but I don't have one (nor do my friends).
Mount the BP face toward the chuck / gear side as tail (don't crush the hooks!).
Use a sharp cutter at slow speed (RPMs) and slow feed.
Cut through the plastic and STOP at/just before the foam pad. Cut down to about 4.875" (4 7/8") OD - NO MORE THAN 4.625" or you'll cut smaller than the fit to the metal housing of the Flex!
Remove from lathe and cut foam pad with a utility knife.
Should take about 15 minutes to do.
Regards,
GEWB
