Brad B
Just recently I had a couple questions posted to me concerning the swirls and light scratches on 3M clear "bra" film. This can happen even during the new application process with the squeegee. Certain applications, Porsches, for example, take extreme stretching and shaping to make the film fit precisely. All this working of the material with the squeegee leaves marks on the film. This is normally invisible on light colored cars but over dark paint, in the right light...swirl city!
Two seperate professional installers, one I spoke to personally, said nothing can be done for this. Well, as a true Autopian and perfectionist I couldn't live with this! They just haven't tried yet.
I called my friend at Reflex Enterprises, the distributors of Xpel, and here is his response:
This is more of a technical question for 3M since they are the manufacturers of the urethane, however I will take a stab at answering this question from my personal experience. First, I would suggest using a new squeegee as older squeegees tend to chip at the edge and can start to leave hair scratches. If I encounter some minor scratches in the film, I use a wax and
a high speed buffer (foam pad only) and lightly glaze over the material. It is important not to apply a lot of pressure to the film as this may lead to burning of the surface. It might be a good idea to using masking tape on the edges to avoid possible lifting of the film if you get to close to the edge with the buffer. I hope this answer helps with the scratching problem.
You might want to check out the 3M website at www.mmm.com which may provide an easier alternative to the scratching problem.
Regards,
Michael Mayall ([email protected])
Reflex Enterprises Technical Support
Voice (800) 447-9928 x 201 Fax (210) 342-8114
So, the basic answer is that it is possible to improve or remove the swirls in the plastic film. I have not tried it yet myself but will likely start with something like Klasse AIO and work up to such things as Meguiars Plastic Polish, then the compliment of superfine abrasives such as Pinnacle Paint Cleanser, 3M Swirl Mark Remover, etc. I will use the softest pad I have on a medium speed. Heat is used to remove the film so keep the heat down!!
Use Michaels suggestion and stay away from edges.
Good luck and post your suggestions.
NOTE
I was in the process of PMing a fellow Autopian on this matter when I lost record of who it was due to the recent loss of posts caused by the "bumbling Mayor"!
Please let me know you got this info. I promised I would follow up and I hate to break a promise!
Regards,
NOTE
