Accumulator said:pwaug- We're just kinda discussing different things at the same time maybe....
Yeah, the general idea is to start gentle and ramp it up so you don't start off using something more aggressive than necessary.
In this case, if blnewt decides to go ahead and do the "big correction" job, I'm pretty confident that the Meg's Ultimate Compound won't be too aggressive (9-year old car, never corrected before..) and I don't see any problem with just starting there. Consider how many people say "I did [whatever] numerous times with minimal improvement!".
Now I understand--makes sense
But your advice is the safer, and perhaps much smarter, approach and the one we generally recommend to newbies.
But I'm going so far as to say to just skip that whole thing for now and give it a good AIO-ing for starters.
You had suggested this to me and it worked out quite well--did my first polishing on my 07 Passat with just HD Speed on an orange pad--it's a great idea--little chance of doing harm and Speed really corrected well even with the hard VW clear
I myself would take a few days and really *DO IT* to that car, but I don't want to turn this into a huge ordeal for blnewt, rather something that'll give really good one-day's-effort results.
blnewt- OH, almost forgot to mention...when it does come time to compound/polish/correct the car, I always work *MUCH* smaller areas than the usually-recommended 2' x 2'. Just works out better for me, even after all the years I've been doing this stuff. So much better that I recommend everybody try doing smaller areas and only work larger ones (like that two foot square) as they gain experience. And even then, even if you do like that, I'd sure watch that it doesn't lead to sub-optimal results.
As a relative novice at machine polishing there is a question that I've had for some time that I think will also help blnewt. As an example-- with my test area I've determined I can get the correction I need with an orange pad and UNO at speed 6 on my GG DA, but it's taking me 6 slow passes with firm pressure. At this point am I better off to go up to HD Cut and/or a yellow or MF pad assuming that then I might only have to do 2 or 3 passes?? I haven't faced this situation with my own cars which were in good shape to start with, but this spring/summer will be doing some friend's and relative's cars that lets say have recieved less than admirable care.
