batesmarshall
Well, today was the day I used my new PC. Luckily I had my wife's '92 Saab to experiment on. When I get the hang of the technique, then I'll go to work on my Passat.
I washed and dried the Saab, then got to work with the PC. After reading as much as I could on the forums, I did the following:
* Put a small amount of 3M SMR on the white foam polishing pad (probably a quarter-sized blob), set the PC on 1, placed it on the hood, and turned it on.
* I first applied moderate to heavy pressure and worked back and forth north to south across the hood. Then after about 15 seconds I turned the speed up to about 4 and lightly went back over the areas that I had already covered.
I immediately noticed that it seemed to be giving off kind of a powdered residue. Is this the SMR, or is the polishing pad disintegrating? (NOTE: I used the white pad that came with my 7336SP, not the CMA pad which I'm reserving for my Passat). Is this normal?
So I wiped off the powdered residue with a terry towel, and it looked remarkably good, for a newbie attempt.
Questions:
* Is my technique right? Anything else I should be doing?
* Am I using too much/little polish?
* Is the powdery residue normal?
The one thing I was unprepared for was the feeling of numbness in my hands after working with the PC for only a few minutes. It feels like I just got back from a 6-hour motorcycle ride!
Thanks for the help!!
// Bates
Questions:
// Bates
