Fine grade OPTI-ERASER reveiw by detailchick
ca.detailchick
My first product review .Miracles do happen!:D
Here is the fine grade Opti-eraser out of the package unaltered(picture below). I've only used it on 2 vehicles. After the first use I decided it felt too grabby for my liking even though it did not marr up my soft Toyota paint I wasn't happy with the grabby feeling (as if it had a suction cup attached to it feeling) .....
I wasn't giving up yet and tried it out on my customers Toyota that I detail every 6 months. It had the same grabby feeling that really slowed my rhythm down .I decided right away to take a razor blade and slice it down the middle and see if that reduced the grabbiness.Sure enough it did and was much easier to do the rest of the vehicle!Here's a picture of the now 2 erasers cut down the middle.......
I played around with how I was holding the eraser to see if there was a way to reduce the grabbiness even more and came up with holding it like so (picture below),with a slight curve to it .(I was actually holding it flater then the picture shows as it was hard to show you without a flat surface against it.) It worked even better and had a much more gliding feeling to it!...Happy now!
I got a little holder for it that wraps around my buckets because on the package it advises you not to soak the eraser.This holder allows it to drain and protects it a bit from the elements....
The surface contaminants/fallout on this car was about average for a car sitting outside for 6 months and I did have to go over the horizontal surfaces many times to get it smooth and a few areas just wasn't getting it smooth enough so I used my magna sponge instead to speed things up.The magna sponge is much more effective than the fine Opti- eraser in removing contaminants but then it does also marr soft paint so its nice to have this option of a fine grade eraser. I would say the fine grade Opti- eraser is comparable to Mothers claybar as far as its ability to remove contaminants.That opinion could change with time as I use it on more cars.
Pros.Does not marr soft paint(so far )
Works ok in removing light contaminants
The price is great considering you get a 2 sides equivalent to 2 erasers for the price of 1.
Cons. It feels grabby and does not glide smoothly ( cutting it helped considerably)
It does not handle anything more then light contaminants/fallout.
Overall its a good product for me after altering/cutting it.
Please, if you have this eraser and are happy with it I would not advise cutting it.We are all different with different size hands and I cannot say you will have the same positive experience after cutting it. If you already have it and are unhappy with it give cutting it a try!
Optimum Opti-Eraser – Fine Grade
That holder is.. GENIUS! where did you pick that up at? :D
Nice review by the way, I have the aggressive grade. I have yet to try the fine.
Its not genius ,it a silverware strainer I picked up at the dollar store!:D
Let us know how you like your Eraser when you use it!:inspector:
Thanks for this review dc. I love the cheap holder idea for it and I think cutting it in half will also work for me.
Great review ca.detailchick. I am considering trying the Opti-Eraser.
Looking forward to more of your reviews.
Looking forward to more of your reviews.[/QUOTE
Im not sure that will happen again.:D
That took me a couple hours to put together.It makes me appreciate everyones elses reveiws even more!:bigups
Excellent Review DC!
...and thank you for your honest thoughts. Now I'm going to buy it, try it and know what to expect.
...and yes genius is taking two separate items that are not normally used together and making it work.
