DESERTCITIES
[/IWHAT IS THE BEST TIRE SHINE/DRESSING THAT GOES ON SUPER GLOSSY AND REMAINS THAT WAY FOR WEEKS? WHAT HOLDS A SUPERB GLOSSY GLOSSY SHINE FINISH,petroleum,SILICONE,WATER BASED?PROS AND CONS...?THANK YOU
DESERTCITIES said:[/IWHAT IS THE BEST TIRE SHINE/DRESSING THAT GOES ON SUPER GLOSSY AND REMAINS THAT WAY FOR WEEKS? WHAT HOLDS A SUPERB GLOSSY GLOSSY SHINE FINISH,petroleum,SILICONE,WATER BASED?PROS AND CONS...?THANK YOU
Anthony A said:Define expert. While your at it don't make an annoying post even more annoying by capitalizing the whole thing.
vtec92civic said:yikes! glossy glossy, huh? just spray paint a couple of coats of clear.
i'm just messing man. Couple of things:
longevity is basically solvent vs water based.
Solvent based lasts significantly longer but in the end is a little more tough to get off of the tire unless maintained and not just left to cake on.
Water based can also be glossy depending on the product but will not last as long at all but is very easy to remove from the tires when comes down to cleaning time.
you looking for a off the shelf product or something in bulk?
swan said:I'm no expert so I guess I can't tell you what I believe to be the best.
I will give you some advice though.
1. Try using the search feature.
2. If you can't find it searching post your question in the right section and not in Motorcycle, Marine & RV Detailing. You will get more response most likely.
3. Don't use all caps when typing.
Tru_Shine said:You guys are Harsh! Is that the way you guys treat a guest at your house? The guy is new to this forum so quite jumping his balls! Yes he posted in the wrong sub forum and yes he type it with the caps lock on, and yes he did ask for only "experts" but he is just looking for an answer not BS from you guys!
JaredPointer said:I would think if you asked any of the hack detailers in your area, they could point to the shiniest, most slingingest stuff sold. My observation has been that the only people who use that shiny, shiny stuff are the hackers.
Black Magic Tire Wet (the one that is clear and smells like "cherry") should fit your bill. It's pretty shiny...
yakky said:And yes, if someone was BANGING on my front door, and when I answered, he starts by saying he only wants to talk to me if I am an expert, yes, he is in fact going to be seeing the front door slammed in his face.
