Epoxy Garage Flooring
Finally got the cabinets for both sides installed and completed. Added some Harley memorabilia and collectibles on the walls.
The two bikes line up and Shamu on the right with lots of room. I've ordered the insulation for the metal garage door inserts.
I'm happy with the way it turned out but I'm burned out on this project and I will be glad when the last items are completed.
Garage Door Insulation on order...
Atlas EPS S-GDIK001 Matador Garage Door Insulation
Universal Kit for 8-Foot and 9-Foot Metal Garage Doors,
Includes 8 White Boards. A two-car garage needs 2 kits
I didn't care for the look of batt or the foil style insulation.
Here's a DIY install video
[ame=http://www.youtube.com/watch?v=ZZOrsOT1REc]Matador Garage Door Insulation Kit - YouTube[/ame]
Garage Door Insulated. Took about an hour to install. Ran silicone beads on the open ends to hold them in place and stop any squeaks.
Atlas EPS Matador Garage Door Insulation Universal Kit. Exposed face made of High Impact Polystyrene (HIPS) Laminate. Looks very finished.
Note: There are residential and commercial kits. If I had it to do over again I'd buy one of each. BTW My hot garage was noticeably cooler.
Why? I have four panels that are 21-1/2" high and four that are 19" high. In my case I had to use my width cut-off as a top filler strip
Residential Panel dimension: 20-1/4" x 54" x 1-1/4"
Commercial Panel Dimensions: 23-1/4" x 54" x 1-1/4"
Something to check before ordering. It's worth the $10. One of each and I would have not had to use a filler strip. I'm happy with the results.
Matador Garage Door Insulation Kits
