imported_Grouse
kleraudio said:From what I understand Aaron (Ive been trying to get into contact with you) is that the foam is the same yes.. but the process the foam goes through is quite different. LC has a closed cell structure.
Your pads go through a different process and come out as "durafoam".
The closed cell format of LC's foam keeps much more of the product on the surface of the foam pad itself. With your (Edge) foam, the product tends to "soak" up most of the product and not leave much on the surface of the pad.
I tried your green and blue and orange Edge foam pads, and it was a disaster using those with SIP. It was squeeling all over the place, it smelled like a "burning" smell, etc....
Now I have not had this problem with 106ff and blue edge, I just need to use 3 times more product to prime the pad. On the LC pads, I prime with 4 dots of product, and use 2 dots every application thereafter.
Now Im not bashing your foam Aaron, you make a great product! Unfortunately it does not work well with the polishes I use most. However I did custom order some wool pads from you and I hope to clarify this issue because your system is really an outstanding system.
As far as the foam processing is concerned, this is just what Ive gathered from making many phone calls and talking to different people as far as foam is concerned.
So yes, they are the same foam, but they are very very different as well.
Jim
I have used edge and Menzerna nearly exclusively. I do not have a problem with either working with the other. It does not dust, spray or sling for me. As for needing more to prime the pad, well I don't know about that as my pads are all edge. Though the guy i work with uses css. He has to prime about the same amount from what i can see.
I tend to wash my pads about every 2 weeks. In between times i use the brush cleaner and store in a baggie.
