dryer machine for microfiber
III
97 bonneville/98 Z71
Who dries their microfibers in the dryer until they are completely dry? I usually will use the dryer until the towels are just a tad damp, then line dry in the basement. I'm wondering if I should change my methods?
Do you think there's less static electricity doing it part dryer/part line dry?
your way is the way I usually do it too...try using a dehumidifier in the room and the will dry real nice:)
I do it your way as well. Drying completely in the dryer would seem like it would cause more static electricity, but this is just my blind opinion.
Your absolutely right Jared; drying completely in the dryer leads to more static electricity. However, with my detailing business, the last thing I need is to spend more time cleaning up supplies...that's a major time eater for me.
I personally dry them all the way in the dryer, then fold up and store away until their next use. I have not seen any adverse affects to the MF's themselves, nor any effect with a little added static electricity (which goes away by the time I use them anyhow storing in outside cabinets).
Hopefully, this adds another perspective, and my method might not be the "best" one available, but it's a time saving method for sure.
Im with you John, hi heat is not kind to the fibers, I dry on low heat, and leave slightly damp.......
I use low heat and dry them on the casual setting. This gets them dry without being too static-filled. One thing I will almost always do is run them through a second spin cycle. It doesn't hurt the towels at all and it gets most of the water out.
