Hey folks,
After recently adding a third DA polisher to my arsenal, I have to wonder. Does DA power make a difference or is it a psychological feeling?
As in any industry, there are ways of tweaking the figures. Because the DA market is fairly closed, there is no defined measurement of power. Many power tools advertise the maximum power rating. Others rate their motors at the normal running power. Why do some companies do this? Well, they can post a higher maximum power rating than a running power rating. For example, a certain retailer would rate their air compressors at a higher horsepower than the competition. How was this accomplished? They used the max horsepower, instead of the running horsepower.
I have a beater 7336, a prototype G110, and a Griot's. During a recent polishing of our Expedition, I used the Griot's for one side and a 7336 on the other side with a MF Cutting pad and M205. Both sessions were timed. While the time for the Griot's was faster by five minutes, this could have been easily attributed to fatigue.
So, to dive into the question...
Does more power save time? Does a higher amperage reduce the number of passes required? Can more power remove more defects?
After using some supposedly higher power DA polishers, I have come to the conclusion that the idea of a more powerful machine is more of a psychological marketing tool. For example, I can't even tell the difference in power between my 7336 and prototype G110. Had I not read that the G110 has a tick more power, I would not have even realized a difference.
To me, build quality, comfort and reliability are much more important than the supposed amperage. If the technique remains the same, the time spent polisher should remain the same. At the same time, if a lower powered DA could not remove the defects, a higher powered machine will perform the same.
In my opinion, the most important thing is technique. The level of bearing resistance is second in determining performance.
What do you folks think?
-Chris
