So far... no negative replies...
I also love the stuff. I even use it spring, summer and fall. I've just about given up the hose procedure.
If the car is REALLY dirty, and I plan to really soak my MF towel with QEW to the point of "dripping wet. I will lay old towels down along the wheels and rocker panels on each side of the car, then just throw them in the washer afterwards.
I've only found a need to do that for mid-winter crud. Most of the time, I wring out the MF so about half the water remains in the towel, and that minimizes the dripping.
Hints for QEW use...
1. Use 2 buckets. (one for QEW water, one to rinse your MF towel or mitt)
2. Wash from the top down.
3. Fold your MF towel in fourths, then wipe each panel once or twice, then turn your towel. This gives you 8 clean surfaces to work with.
4. Always rinse your MF or mitt in the "clear water" bucket after wiping the car. (8 passes)
5. I don't even worry about drying the car, because I always follow my wash with a QD spray. It's usually pretty dry by the time I'm finished.
6. Wash the wheels last, follow with QD or Spray wax.
I can usually do a QEW wash in about 20 minutes, then follow with a 10 minute QD.
That's basically all there is to it. :xyxthumbs :xyxthumbs
