Accumulator -
When you're spraying the foamgun at point of contact, I assume you're dispensing at that point (also assuming it has the option to switch to just water). So are you spending a lot on solution for the foam gun? I bet you can guess my next question: any suggestions for foam gun solution?
Is this the Gilmour you're talking about?
http://www.amazon.com/Gilmour-75QGFMR-Foamaster-Adjustable-Cleaning/dp/B000XTH1GY/ref=sr_1_2?s=lawn-garden&ie=UTF8&qid=1389821198&sr=1-2&keywords=gilmour+foamaster
I'm still going to have to wait on the BHB. For now I think at least switching mitts will help. I've narrowed my choices to these:
- http://www.autogeek.net/sponwasmit.html
- http://www.autogeek.net/carpro-wool-wash-mitt.html
- http://www.autogeek.net/2in1washmitt.html
- http://www.carpro-us.com/microfiber-madness-incredimitt/
2 is only one-sided, I like being able to turn it over and get more use between rinses.
3 might as well be one sided most of the time. Plus that nylon mesh worries me as far as marring.
And I know 4 isn't wool, but people seem to love the thing. It seems to share the benefit of easily releasing the dirt like wool.
I'm also considering the LC Ulti-mitt. People rave about the sponge version. This is the same thing in mitt form.
I actually like using the mitt as a mitt. It helps me not drop the thing. So I gotta ask, what exactly do you mean by "whisk"? I'm picturing just lightly brushing it against the surface of the paint is short strokes, quickly lifting it away, so that the full brunt of the thing doesn't make contact. In my head this seems like it wouldn't really remove much, especially when I get to stuck on bug, bird stuff, etc. Currently, my technique is to lightly glide the soaked mitt across the paint, with my hand inside. I don't press unless I get a trouble spot that just won't come loose. And then I localize the pressure.
Full flow quick disconnect... I am using one of these
http://www.amazon.com/Gilmour-Garden-Connector-Shut-Off-03V/dp/B0006U66B6/ref=sr_1_1?s=lawn-garden&ie=UTF8&qid=1389821052&sr=1-1&keywords=shut+off+valve
immediately followed by this
http://www.amazon.com/Gilmour-Brass-Hose-Quick-Connector/dp/B0008IT0GE/ref=sr_1_3?s=lawn-garden&ie=UTF8&qid=1389819965&sr=1-3&keywords=gilmore+quick+connect
Actually, the shut off valve is a slightly different design, but same thing. So is that "full-flow"?
dfoxengr -
Is the 75 I posted above the one? Yeah my entire prep (as in getting all my crap together, not claying etc), wash, dry takes around 2 hours. The wash is probably... actually I have no idea, if you include door jams, and wheels, yeah no clue haha. Hey if the foam gun is gonna save me time, I'm even more all for it. But the brush still has to wait. I really need to get quicker.
