wannafbody said:I have my doubts that OHC by PC will work but with an orange pad it might have enough bite. SIP is a better choice. If you have a paint supply store nearby 3m 3000 rubbing compound would be a good choice IMO.
evenflow said:does the 3000 work well with the PC?
Might have to bump up to a yellow pad I guess.
evenflow said:My original process was going to be..
OHC/IP via PC/6
FPII via PC/6
Souveran
Looks like I might need to switch around now since the OHC/IP might not get things done the way I wanted.
ptaylor_9849 said:Evenflow, I'm from MA as well. It took me many, many months to figure out corvette clear coat. I've had two vettes during the last 16 months. One being a black C6. Then I smartened up and got a yellow 2007 Z06 that is much more forgiving. Some combo's are too aggressive and leave major hazing while others weren't strong enough and didn't do a damn thing. I will tell you this from experience, corvettes are best handled via rotary. That said, I found two combos that worked really well. First was a purple foamed wool pad with 106ff and the other was SIP and an orange pad. Try your products but be forewarned that a P/C might not do much for you. What color is this Z and please don't say black.
Patrick
ptaylor_9849 said:Be very careful wiping away residues with your microfibers. Corvette black is so sensitive that it will marr even with a sharp edge of a microfiber.
