I will be detailing a car soon and the last time I detailed this car, it required two full clay bars and way too much time. This was a few years ago and I had never used a Decon system. So this time around, to save time I am going to incorporate a decon job but as bad as I am assuming this car will be again, I am thinking Decon alone may not be enough, probably will require both decon and claying.
So, should I decon first and then clay afterwards with the assumption that the decon will make whatever claying is left over much easier
or
She I give it a quick over with some clay to knock as much as possible from the surface to give the decon acid a chance to get to the pores.
In the past, I have clayed WHILE using the acid step of Decon. The first time I tried it, it worked pretty good. While the clay was slowly degrading and had to be thrown away afterwards, while it was holding together, it was like clay on steroids, just ripping the contamination right off the paint with just one swipe of the clay unlike the first time I did this car where I was having to work sections NUMEROUS TIMES. Then I tried this claying while acid method again, and for whatever reason, the clay was degrading much, much faster and was smearing all over the paint.
I am hoping I can clay while acid method again but I have a bad feeling the fast degradation of the clay will happen again so I better be ready to separate the steps, I am just wondering, which to do first.
or
